Nedding Advice
I have a 20 mono hull and a 20 road runner rigger hull I am turning in to Electric need advice on motors ESC this is what I have now.
Brand: Racerstar
Item: 5900KV Motor
Waterproof Level: Splash-proof
Features:
- 4 pole 12 slot hi-torque motor design
- CNC machined 6061 T6 billet aluminum heatsink can
- High purity copper windings maximizes efficiency
- High RPM ABEC 5 oversized bearings
- Universal fit, fits all 1/10 brushless cars; multi-mounting system for M3 screws
- Precision balanced rotor, smoothness for best reliability and maxium RPM
- Stator- super thin (0.35mm) laminations
- Removalbe/replaceable rotor
- Precision engineered for maxium energy coversion
Specification:
Watts: 900
Max Voltage: 8.4V(5900KV), 9.6V(5200KV), 12V(4300KV), 13V(3900KV), 16V(3100KV), 22V(2300KV), 24V(2050KV)
Max Amps: 107A(5900KV), 94A(5200KV), 74A(4300KV), 69A(3900KV), 56A(3100KV), 41A(2300KV), 38A(2050KV)
Rotor Poles: 4
Max RPM: 50000
Length: 50mm
Diameters: 36mm
Weight: About 180g
Shaft: 3.17mm
Length of Extend Shaft: 15mm
Connector: 4.0mm Gold
ESC is Water-cooled 70amp
Thanks for the help.
