I think what you will find on most spinners is the openings will be to small for that big APC. I like to find the size that looks best on the plane and cut if need be. The exception would be a Tru - Turn spinner. They will cut the opening to fit your prop. I have good luck with the Dave Brown spinners from Tower. If I have to open them up I use a marker to mark both sides and carefully sand the opening bigger with a Dremel drum sander. Since this is an ALUM spinner you can use a prop balancer to re balance it when you finish.
David
