Not familiar with your TX Ken. I assume you have the mix set to 100% on both. If you were doing a Futaba you have to set that gear channel to null before it will operate as a linear mix. Otherwise it thinks its for gear and will only go full up or down.
Someone that knows that radio should chime in.
David
