Originally Posted by
drac1
In regards to fuel tubing, I'm not convinced that is a issue. I've used YS tube, Dubro medium tube and now Prather medium which I've been using for a few years now. Haven't had problems with any of them. But whatever works.
For the 185 Red and 200, the manual specifies that the carb to injector line, (tube C), must be a soft tube with 3mm ID and 5mm OD. This is to do with the new injector not having the check valve on top.
my my problem was that the tubing kept splitting. Even the Prather medium line.
