could you make the delorean body fit a Tamiya TT-02 and the specs are ●Length: 376mm, Width: 182mm/190mm ●Wheelbase: 257/251mm ●Tire Width/Diameter (Front & Rear): 24/64mm ●Bathtub-type Frame ●Shaft Driven 4WD ●Front/Rear 4-Bevel Resin Differentials ●3-Piece Steering Tie-Rod ●4-Wheel Double Wishbone Suspension ●Front/Rear CVA Oil Shocks ●Gear Ratio = 8.27:1 (10 further ratios from 11.38:1 to 7.28:1 possible with use of separately-sold pinion) ●Type 540 Sport-Tuned Motor ●Full Ball Bearings
