I agree with the thoughts on pressure testing it is truely the best way to find case defects and shaft seal leaks . I have also pressure tested with smoke to locate leaks which is also a great way to check leak locations . I had access to an automotive evaporative emissions leak tester befire retiring and it was an incredible time saver .
