It may be a bit late for the OP, but I've found that if you glue the front of the sheet to the leading edge, wait for it to dry, then spray the sheet with regular old Windex, the sheeting will curl on it's own, and will only take a little bit of coaxing to lay down where you want it. I just use masking tape strips to hold it in position while the glue dries.
