Is there a contest restriction against using a reduction drive with the engine ?
If there is a displacement restriction then bigger loads can be more easily moved with a reduction drive turning a higher pitched larger diameter prop .
+1, a reduction drive could go a long ways to improving prop efficiency. When pulling a heavy load, there is just no substitute for larger prop disc area.
