Old 02-08-2018, 06:46 PM
  #42
rbgetz
rbgetz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Received the kolm mounting hardware. They sent 4 standoffs and a front mount bracket to support the engine. The 4 standoffs will need to be drilled 6 mm so the threaded 6mm bolt will slide through. They were not specifically design for this and had different threads on each end. So, obviously that won't for this setup, without boring them out. . I then drilled ( 5.5 mm) and tapped the four mounting holes on the engine. The 6mm mounting bolt will push through from inside of the firewall and thread into the engine.
ID:	2253958   Click image for larger version
rbgetz is offline
