Hello David,
Actually went up to 140 PSI for 2 flights with no luck. The gear when connected direct to the pump operates with minimal pressure and smooth.
Water trap has been there from day 1. Suspect the valve as even the nose did not retract.
Any experience with the JMP high flow mechanical valve?
Regards
Chatty.
