Originally Posted by
c_makhija
Hello David,
Actually went up to 140 PSI for 2 flights with no luck. The gear when connected direct to the pump operates with minimal pressure and smooth.
Water trap has been there from day 1. Suspect the valve as even the nose did not retract.
Any experience with the JMP high flow mechanical valve?
Regards
Chatty.
Hi Chatty,
can only conclude it’s the valve.
I have no experience with JMP but I guess it will be top quality.
However, as I said earlier Jet Tronics works perfectly on my AirWorld Hawks and the Intairco dual valve system, gear and doors, has proven perfect for my SkyGate Hawk !
So so it’s a valve change!
David
