RCU Forums - View Single Post - CARF Galloping Ghost build
Old 02-16-2018, 08:47 AM
  #57
TBruce
Default exhaust holes
Originally Posted by rbgetz
Test fit the engine again to get the exhaust tubes to fit out the bottom. Took several times to get the holes aligned. Now that they're centered, I just need a little more trimming. Used hysol to mount the engine front support bracket to the lower cowl. All seems to align nice with the spinner. Need to install throttle & choke servos on the other side of the firewall.
Robert the build is looking great your posts are a great help to the build we have going on here, thanks for all the great pictures. Would you mind giving the measurements for the holes you drilled for the exhaust. Thanks
Todd
