Originally Posted by
kevinthoele
These valves are highly susceptible to moisture. I know you say you have a trap but I will bet it is full of moisture. I did an experiment in Houston and the trap lasted less then one day before full of moisture. Best way to fill tanks is small scuba bottle with stage reduction for pressure
or change to mechanical valves like JMP UP style. Good luck with your diagnoses and gear working flying!!!!!
Guess your right, will change to the JMP valve if this one does not deliver.
Been using the BVM mechanical valve for more than 10 years now in all my sport jets, never a hiccup.
Chatty.
