Sea plane with raised engine pylon.
I did raise engine pylon 1 inch so I can use a 13 or 14 inch prop. I am going to try first flight with a 13 x 6 three blade, but also have a 14 three blade prop just in case. As I over built plane and it weights close to 10 lbs. I changed engines and put in a Supper tiger 90. I am sure this is more than enough engine and should be able to fly at 1/2 speed. My Sea Dancer is all ready to go, just need some warm weather up here. to try her out. Thanks to everyone for help. K C
