Originally Posted by
lALXl
Ok, thanks man, I really appreciate your help. So that means that I have to get a new battery and the problems should go away, doesn't it?
I don't know.
You only have one set of batteries?
You need to troubleshoot something. Either test the batteries or try a known good set.
Or get a good 6 volt receiver pack, plug it into the receiver (don't plug the main batteries in) and see if the servo issue still exists.
As stated, you may have got the receiver or ESC wet and damaged it.
