Originally Posted by
RustyUs
LVC differs from ESC to ESC. Having it set low, e.g. 3.0v/cell, might not be such a good idea if running a pack that is known to have a bad health issues (high internal resistance). If you have a LiPo pack with cells that hold their balance well, then lower LVC settings won't be an issue. I would not recommend a low setting on the LVC unless you know the ESC and your packs well. Normally, I would have packs come off the track reading 3.4v/cell after the LVC completely shuts down. Now I just set all my ESC's LVC to 3.4v/cell, if option is available. Voltage from my packs will usually read 3.7v/cell after a LVC triggering/shut down of ESC, and the pack sits for 10 seconds.
Possible that OP has run through some water?
Yes I ran it in snow but the battery was waterproofed by me
