Looks like you are going in the right direction with the install, as mentioned above. Personalizing a model airplane makes it very unique to the point that you can absolutely say with certainty that there is no other one like your airplane and that is very rewarding because you know you build it
I will be getting my kit from Bruce's shop soon and have set a week a side to start the building it, I have been reading the manual to be ready to start building without delays, will get all the glues and building door soon.
I also will be using a P60, with that in mind I have decided to build it per the instructions but have a minor mod in mind already ( no blind nuts for the retracts mounts ) I will be using air retracts and a combo of digital and analog HS servos.
