Installing forward as much as possible are very good points
The UAT will have to be as close to the main tank as much as possible, I may add a second tank forward of the main, things that could go in the nose, the fuel pump, batts, retract valve and servo, break servo and valve, on off switches, jet nose wheel, since the main retracts are so closed to the CG I will be using jet wheels and Robart struts
