Progress Report - Bob Parks Intakes
I had a very long, busy, and productive weekend. The wing is almost finished (need to finish the bottom side fairing) and mated to the fuselage, and, the intakes are built. Still have to add the upper skins and inlet lips but thought that sharing pictures will help those that plan on building their kits. Notice the brace in the rear view picture. This brace determines the distance between the side walls so that once removed - the turbine will fit on the mounts. When the time will come to install the turbine, I will have to trim the 1/32" plywood that is glued to the fuselage and supports the intakes.
