Let's see the last project, we started with an Integy chassis for wraith:
" target="_blank">
by https://www.flickr.com/photos/126459290@N04/, en Flickr
And we have a donor:
" target="_blank">
Start the wiggle, first dismantle the gossip, put the electronics that will take as the donor will not be, and try everything to see what remains and what is needed:
" target="_blank">
" target="_blank">
" target="_blank">
Once you have tried everything, with what it has cost to put the seats and others in there, we already have results.
Eat already wise of first, complete wheels.
And after seeing it and doing tests, it will be necessary to make some links to remove a 5mm of battle for him and that between the servant in its place and of step to put letters of 4 and to replace the worn plastic balls by metallic ones in the links that do not we will make new ones.
I have also taken measurements and will have to put some shock absorbers chords, 100mm in front and 110mm behind.
We start with the painting, first a primer:
" target="_blank">
And second, color:
" target="_blank">
We started the final assembly:
" target="_blank">
" target="_blank">
" target="_blank">
" target="_blank">
" target="_blank">
" target="_blank">
" target="_blank">
We received the shock absorbers !!
" target="_blank">
" target="_blank">
" target="_blank">
AND WHEELS
" target="_blank">
" target="_blank">
" target="_blank">
" target="_blank">
