Horizon just introduced a new foamie with CLEAR WINDOWS. The Maule M-7 1.5m. This airplane looks like it could be the new standard bearer of STOL models in the 1300-1700 mm range.
While America geared up to go higher and faster, B.D. Maule was hard at work in a quiet country corner developing his vision of an aircraft that would give pilots the ability to do the exact opposite—practically. Maule Air Inc. has flourished ever since by delivering planes around the globe with renowned STOL capability and value. The E-fliteŽ Maule M-7 1.5m park flyer is an officially licensed tribute to the full-size marvel that includes an abundance of scale detail, rugged landing gear, flaps and an optional-use float set so you can conquer any terrain year-round."The E-fliteŽ Maule M-7 1.5m captures the Short Take Off and Landing (STOL) capabilities, along with the unmistakable lines and character of the rugged full-scale design series. From the crystal-clear cabin windows and interior detail to an abundance of exterior features including LED lights, antennas, vortex generators and riveted panels, the Maule breaks new ground in park flyer-size civilian scale authenticity. EPO construction results in a lightweight yet durable airframe. The two-piece wing is equipped with operational flaps for outstanding slow flight performance and STOL capabilities. The factory-installed 3S and 4S compatible brushless power system delivers plenty of performance for flying from smooth or rough surfaces using the oversized wheels, or when flying from water using the included float set."
https://www.horizonhobby.com/maule-m...d-ss-p-efl5350
