The fiberglassing of the wing went well. It was much easier then plastic covering. The fiberglass conformed to the surface much more then I through it would. After I put the primer on I noticed some low spots that Ill need to fill before the next coat of paint goes on. What do you guys use for filler over fiberglass?
