Originally Posted by
skunkwurk
Hello Xantos,
Great jet, you are going to love it. The Rebel is my daily and can't imagine not having it. This is what I did, hope it helps. Note that I installed wheel collars & a little piece of tubing to create a soft stop when pulling/unlocking the canopy against the carbon rod guides. I hysol'd plywood blocks where the rods exits the canopy in the back and sanded down the exit in the front to ensure smooth operation. I included a couple close shots for you to see the ends and collars. Rod guides are hysol'd in for a smooth fit. Please be mindful of Mauro's suggestion. If you are not careful the rods or guides may hit the top of the fuselage when installed. I tried to keep mine as symmetrical as possible and clear everything. Works great.
Hey Thanks for the Pics it clears up things .
Another question - Im planning to run a Rhino 200 , are the Intakes big enough to let the Rhino breathe or should I consider cutting out NACA inlets in the fuse ?
