Originally Posted by
PMracer
Todays SAGA !! UNCLE !!
Air bleed from 1/2 turn up to and including 4 turns, nothing.
I am assuming that you screwed the idle screw IN to increase fuel draw? Remember air bleed idle setting is backwards. I would try screwing the idle screw all the way in to see if fuel draw improves. That might help isolate the source of the problem better.
