Eitschpii,
Thanks for the gracious reply.
Would you consider raising your maximum size from 1.15m to 1.2m? The reason being it would include a bunch of 48" models for your consideration such as these:
https://twistedhobbys.com/airplanes/...irfoil-series/
They are carried by Lindinger in Austria under the Pichler name, see:
https://www.lindinger.at/en/airplane...tic-airplanes/
While viewing the twistedhobbys site be certain to look at the PDF manuals available for downloads and construction videos on youtube.
The Skylark is small at 950mm, my weights straight out of the box are:
Skylark Weights
Component Weight(grams)
Fuse 304 Includes motor, ESC and 2 servos
Left Wing 60 Includes 1 servo
Right Wing 62 Includes 1 servo
Stab 20
Rudder w/TW 13
CF Wing tube 20
Prop 10
Prop adapter 7
Hardware Bag minus glue 36
LG wheels & pants 71
Total 603 Add your battery and receiver for its takeoff weight.
Wheel pant 16 I intend to save 32 grams by not using them because I fly off grass.
Regards, J e r
Member MHRCS "The Rhinebeck Jamboree People"
