Avistar Right Thrust
So what I did was take a straight yardstick and drilled in the center (at 18") a 1/4" hole so that I could mount it behind the propeller. The longer length shows the right thrust better. If you notice, from the tip of the left yardstick it's 8 3/4" and on the right it's 7 3/4" , which shows the right thrust. 1.6°
Reason: added content, enhanced
