Old 03-28-2018, 05:08 AM
CK1
My Feedback: (60)
CK1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the carb tuning doesnt resolve the issue and you have eliminated all possible air leaks know that some of the early production DLE 20 had an ignition module with a strange advance curve. The timing would hang in advanced timing at lower rpms just above idle . A new ignition from Rcxl or Rcxp should reolve the problem . If you have a newer engine less than a few years old check the throttle butterfly for proper positioning in the throttle bore. Be sure to remove the idle stop screw in all cases.
CK1 is offline
