I suggest you do a thorough research on the web about them as there is a lot to choose from, a lot at useless and in my opinion, the detector could be just as good or just as bad as the person behind the wheel. Most people that buy them to get away with tickets and have no clue how they work often get more tickets with the detector than without.
First, a radar is useless against laser so if your local PD uses a lot of laser you may want to reconsider, depends on what is going on in your local area.
If your research turns you to it, you can go purchase online. I also have one that has a connection for iPhone
Reason: Last line seemed a bit suspicious.
