Toledo RC Show and my F-4 for static display and judging. My B1RD didn't place. Next year when it's all complete.
Originally Posted by
dionysusbacchus
You're welcome. Won't be the easiest plane to see, but some fly the all black F-4 at this smaller size no problem.
I have a picture of my elevator servo. Push-rod has no side to side movement, I just stuck some plastic tubing on to make sure I guess. I stiffened up the stock push-rod with some carbon tube.
Your elevator has more space on either side of the fuselage than mine. Also the left elevator is titled down more by about a half inch. So my elevators rub a lot on the sides. Second is there is only one screw for each wing in the front holding it in place. This allows for the trailing edge to slide out a bit on the rod. I believe there should be another tab at the back end also to screw into for a more secure attachment. Any thoughts??
