when you say idle mixture do you mean the idle gap or the LSN?
I tried starting it at your rec. settings and it was close enough to almost start and i leaned it out a touch more and sure enough it fired right up. Its still running way to rich, i only had about 30min all together so i leaned the HSN about 1/4 turn and the LSN about 1/3 of a turn and its running strong but still too rich. Im going to keep tuning and leaning it out an hour at a time tomorrow morning. I really appreciate your help, idk where lrp gets off saying the LSN should be 3.5 from closed... if it wasn't for you and this forum i would be trying to start a ridiculously rich engine that obviously would not have started.
How fast should the temp reach the 200's, when its say 60 outside?
Thanks again
