What I did was simply mount the electric motor with the x-mount to the inside of the firewall nose. When putting the prop shaft adapter on, it made the correct space for the spinner backplate.
I did have to widen the hole where the prop shaft would stick through a little. But this was the easiest method. Of course, the built in wood glow motor mount rails needed to be dremeled wider to fit the drum of the electric motor.
