RCU Forums - View Single Post - Monster GT Revival
Old 04-14-2018, 11:25 AM
hilifemt
hilifemt's Avatar
I have received everything for the conversion except for the center diff mount which should be here soon, hopefully. I went with a Kyosho center diff with a 46 tooth spur which has the same size teeth/pitch as my 46 tooth MGT spur. I thought that was 32p but the 2 32p pinions I ordered don't mesh up right with the spur gear. I'm looking for a 16 tooth pinion with 5mm bore. My closest hobby shop is about 2 hours away so I want to make this next order right, hahaha. What pinions do I need and what gearing can you suggest. I knew my gearing well with the transmission but not certain with a center diff. Any help would be great. Thanks
