RCU Forums - View Single Post - BJ Craft Eternity
Thread
BJ Craft Eternity
04-15-2018, 08:26 PM
27
shannah
My Feedback: (
5
check the fuselage to make sure its level. I used the wing saddle and my eyeball for sanity check
install the stab tube and the FR4 washer
Check to see that it is level
CA glue in the tube socket
Before installing the flying stabs, I line the root with Felt.
Put one of the plywood disks on the tube to act as a spacer. This will help make sure you have not mounted the stab too close to the fuselage and have too much drag in movement. Obviously, you remove that spacer after you have finished the installation of the stab tubes.
If you look at the stab halves, you'll see the one with the hard point installed. Right side.
Drill the hole through the tube after you position the stab in its final location. The hardpoint is predrilled, the tube and socket are not.
Glue the stab tubes into the left side. Final fit looks good.
03:58 PM
Reply
Like
shannah
View Public Profile
Send a private message to shannah
Find More Posts by shannah
View iTrader Profile
