Originally Posted by
rhklenke
My airplane was *packed*! There is no room in the nose section (I had to make the cockpits shallower as Dom did to have enough room up there). My turbine stuff is wedged above the intakes, and the fuel tanks surround the front of the turbine beside the intakes. There *might* be some room under the engine mounts, but not a lot. You also have to be concerned with adding additional weight - especially with a 120 class turbine for power.
Bob
Bob,
Thank you for the info. I was thinking it might a tight fit. I changed my scheme from Camo to Thunderbirds for visibility and then if I decide to convert to G model, then I will paint the wild weasel scheme. Since the Thunderbirds performed, smoke would be cool. Still trying to decide between k120 or K140. There is still time before my jet arrives.
Jeff
