Thank you for your help, knowledge and understanding. I am sure it will help many of us.
I currently have the LGC13 in the Ultra Flash. It seems to give me more Brake resolution (i.e. more movement of the slider between off and full on). I also set back the maximum force so that they will not lock up at full on. It seems to be working O.K..
With the LGC12 and transmitter's Brake channel set at -100/+100, if the zero to full braking happens in two clicks (about 1/10th) of the slider's travel, how do I spread that braking out over the entire travel of the slider?
