Originally Posted by
Felix Barrao
Thanks for the picture, seems big, ( just comparing the size with the mpx conector and kero plug), any data of diameter, weight, etc?
This is all that I can find, 65,5mm diam. 160mm length Kerostarter, valves and Fod integrated, price around $1500 AUD
, No thrust figures, but 30 newton is approximately 7 lbs thrust.
The JetCat P20 is, by comparison,
- Thrust: Thrust 5.25 lbs ( 2,4 Kg)@ 245,000 RPM
- Weight: 13 oz. (362 gram)
- Diameter: 2.4 inches ( 60 mm)
- Length: 7 inches (180 mm)
- Exhaust gas temp.: 580°C-690°C
- Fuel consumption: 3.5oz/min at full power ( 90 ml)
- Fuel: Jet A1, 1-K kerosene
- Lubrication: approximately 5% synthetic turbine oil in the fuel
- Maintenance interval: 25
