Originally Posted by
speedracerntrixie
The 20x13 three blade prop is too much for a 220 KV motor. I'm not familiar with that speed control and have no idea what factory settings are but for a large outrunner the timing should be around 23-26 degrees. If for some reason the speed control factory settings are for an inrunner then the timing would be set to no more then 10 degrees. I can easily see where with that prop and with running an unknown timing setting just about any brand motor is going to fail.
Direct quote from Dualsky below
“You mentioned that you used PT 20x13, but if it's 3-blade propeller. The load was too much for XM6250DA-220KV. This maybe the reason.
The right setup is : 20x13EL(3-blade), XM6355DA-13 200KV.”
This is what I was running when the magnets came loose. Dualsky replied to my replacement request about 10 days after my email requested further information on setup. This was sent over 7days ago still no response. The customer service they offer is nonexistent.
