Originally Posted by
Kh@n
Hi all,
Can anyone tell me if the stock fuel tank is ok to use? Whats the idea with the metal ring. Im used to assemble such tanks with a bolt in the middle, that tighten the rubber insert for airtight fit.
/Henrik
I originally installed the tank that was supplied with the plane, however, like you, I was questionable as to the reliability of it. I found a tank from Valley View RC, a 32oz version that basically fit right in there and seems to be a much better set-up. Hope this helps .
