Hi I am wondering if anyone has encountered this on the Spektrum AR636 receiver;
I programmed all the surfaces using the app but in testing the output responses I am successfully able to get the elevator to go up when I nose it down, left aileron to go up when I rotate to the right, but when I yaw the aircraft to either way the rudder deflects in the same direction. The rudders servo direction is correct with normal control inputs (breaks to right with right input and vise versa). The receiver mounting orientation matches the app. I have researched a lot and not found anything on the web about this. I would appreciate anyone sharing their setup verification on this.
