Stihl ms660 RC conversion project summary
Prop size:
Max RPM:
weight of engine (incl muffler, ignition, ign battery, drive hub etc) :
weight saved by not using the original ignition:
engine thrust:
cost of engine (as you go it):
cost of parts added:
weight of Klemm plane:
Additional questions:
1) Did you run the chainsaw before you pulled it apart? If so, how did it run?
2) What was the condition of the cylinder lining?
3) How much running had this engine had before you got it?
4) How much gas does it burn in say 10 minutes of flying?
5) Are you on 2.4 GHz or 72 MHz ?
6) What other props did you try?
Sincerely
Christopher Knee
Richards Bay
