Old 05-24-2018, 11:54 AM
  #71
Saillfish
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by gunradd View Post
Yes my son broke both of them over time. He has around 300 flights on his now. Really good flying plane. If you are building one new I would think some G10 hysoled on the backside of the gear plates would work well. Also where the wing attaches inside you can see a lightning hole in the wood. I used a dremel to remove the aircraft skin so you have some room for a hysol nozzle to fit in to repair the gear plates. When the wing is on it covers the small hole.
For your flap issue maybe try a heat gun and you should be able to straighten it.
Thanks for the info on the gear mounts. I tried the flaps with a heat gun. No luck. Stayed a few hrs and then went back. Do you have any down elevator mixed in with full flaps. Also do you have any crow in yours. Thanks
Saillfish is offline
