A supplier for the landing gear has come forward and he is busy making the first set for testing. The kit is electrical and will be provided as a complete system, ready to bolt in! The final price is not in yet determined, however he is confident it will be less then $2200.00USD.
The other good new is SC Models is busy on the plugs and mold to make the cowls; same for port and starboard; the nacelles; they are the same shape inboard and outboard so it is a matter of cutting out the wing slots to make them a port or starboard nacelle, the equipment hatch , landing gear bay doors and the aft chunk that will attach to the flap! The Set if their estimate to me works out should be less the $1000.00USD delivered to you
I founs a CF tube supplier that will provide CF parts cut to fit and ready to install. That way you are not buying tube that you are only using a small part oF. On the BKA it saves the modeler >$150.00.
