RCU Forums - View Single Post - B.J. Super Fantasista
Thread
06-19-2018, 03:42 AM
23
J-P
My Feedback: (
1
Stabilizer installation
Fred used some black venilia velvet on both sides, giving a minimum friction and quite no gap with the fuselage.
First the tubes are drilled on one side using the screws coming with the kit, then the other side of the tubes are glued in the stab with 30 mn epoxy.
You can easily check for the right friction.
When dried, you just have to remove the two screws if you want to remove the flying stab.
In order to secure the front tube glued, Fred drilled a hole trough the socket and the tube and glued in a small carbon rod.
03:57 AM
Reply
Like
J-P
View Public Profile
Send a private message to J-P
Find More Posts by J-P
View iTrader Profile
