Old 06-28-2018, 01:46 PM
mirce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the fuselage there are channels that bring the air directly to the turbine.
In the front fuselage part, the channels have a mild curve, so they have to be made of balsa strips that are placed next to each other.
I used CA glue for this process.
The channel in the rear fuselage section was a bit easier to make, because the shape is correct, only in one place it has a slight changeover.
To make balsa easier to bend I used hot water and I used a white carpentry adhesive for gluing.
When you assemble the fuselage you can see how long the suction channel is.
Mirce
mirce is offline
