Old 07-05-2018, 12:46 PM
  #664
Dsa44
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by MikePS View Post
So I'm getting much closer on this, should be maidening next weekend. I wound up mounting the wing servo's directly to the servo hatches. Going with the 12S 8000mAh will result in needing 7-8 oz of lead in the nose. Will be inserting them end to end, not side by side. Last bit of work is to attach the clear portion on the canopy to the rest of the hatch (canopy glue) and mount the antenna. Curious how others may have mounted theirs....just drill a hole thru the top of the fuse?
Also, mine has 3 small holes on top of the removable cockpit, where the antenna mounts directly.
Dsa44 is offline
