I had a similar problem that turned out to be a bad servo pulling the battery way down. It was binding internally on power on. Servos pull significant power when they move, enough to pull the battery down. but since the movement is so short it normally doesn't affect anything. I found mine by starting with all servos disconnected and then adding them in one at a time and verified it by having just the one bad servo connected and still seeing the problem.
