It seems that the cable from rx to esc had a shortcut, its a burned spot on the belly pan where i guess it happend. Replaced both esc with another Spin 99 and cable yesterday, do a proper cleaning inside and outside fuse and checked out that everything works so most probabely I will have it back to air tomorrow. My model has different wing than the original, Ola Fremming build a more svept back vings and also a bigger rudder som my rudder authorities is much better than the other Oxai Azurit i also have. I use around 2900 mAh in a 7 min flight with 4600 batteries but I never flew more than one rounds of maneuvers so that ok for me.
