RCU Forums - View Single Post - LOCKHEED P-38J “LIGHTNING”. A giant 1/4 scale scratch built model
Thread
07-20-2018, 09:00 AM
25
fbielsa
In the same way, once the bottom sheet and the Fowler hinges of the flaps have been glued, it is necessary to glue the tube cover, taking care to do so with the wing mounted on the central section and reviewing its holes in the ribs until the bottom edge fits perfectly. The wings are attached to the central section with one M4 screw and positioned with two hollow aluminum dowels. Finally, the upper surface can be sheeted. The ailerons are cut off from the assembly and hinged with flat hinges at the top. The flaps are carved in solid balsa too.
Reply
Like
fbielsa
View Public Profile
Send a private message to fbielsa
Find More Posts by fbielsa
View iTrader Profile
