so the First units are send out to customers.
now few things that are important :
if you use the OLD lua remove it!.
New lua 1.5
CTU Release 1.0
1 . Unzip the zipfile in a free folder.
2 Copy the CTU.lua into the apps folder on your transmittor
3 .copy the Folder "Digitech"AND its content in to the apps folder.
4 copy the CTU.bin into the folder "Devices"on your DS or DC series "
connect the CTU to a EX port on your receiver , make sure it is set to EX/serialbus
the RED led should blink slowly if set correctly / it will blink fast if its not set correctly.
go to Timers/Sensors
go to sensors/logging setup
press auto to rescan
now you can add the sensors into your Telemetric display
you can set the CTU in the device explorer.
Whats new :?
Device explorer support JETI
Double screen
Languages added :
spanish
French
german
dutch
Added : Fuel low warning settable by percentages of 10%
added : Vibration warning
Added , Startup messsages can be turned off and on.
Firmware & Programmer for CTU:
https://www.dropbox.com/s/1jajgujz7i...mmer.zip?raw=1
LUA & Soundfiles & Bin file :
https://www.dropbox.com/s/nqde3zry52...-1.5.zip?raw=1
