RCU Forums - View Single Post - Northeast Aerodynamics Sport-Air Build
Thread
08-02-2018, 10:25 AM
25
VincentJ
Got all the shear webs in place (back view).
Here's what they look like from the other side.
While not called for in the plans, I added some triangle stock for additional bracing/support on the ribs that support the landing gear mount.
Well after some considerable time cutting and fitting those compression sheets (shear webs), I got them all to fit pretty well. I added (epoxied) a small 1/8" plywood support to the back of leading edge that will give the wing alignment dowel the support that it needs. Sorry I forgot to photograph that. Soon as the epoxy sets-up I'll be able to sheet the rest of the wing as outlined on the plans.
Building Tip: While it may seem obvious, strive to get all of your wood joints as tight as they can be. Loose/ill fitting joints will fail over time. By taking the time to get your joints tight, less glue will be used and of course you will not only have a stronger plane, but you will have one that weighs less...
10:28 AM
Reply
Like
VincentJ
View Public Profile
Send a private message to VincentJ
Find More Posts by VincentJ
View iTrader Profile
